process-cpu
    Configures the EX3500‘s CPU (processor) utilization rising (upper) and falling (lower) threshold
      values. Once configured, the system sends a notification when the CPU utilization exceeds the
      specified rising limit or falls below the specified falling limit.By customizing an EX3500‘s memory and CPU utilization‘s upper and lower thresholds, you
        can avoid over utilization of the EX3500's processor capacity when
        sharing network resources with an NX series service platform or a WiNG VM.
        - Service Platforms — NX 95XX, NX 96XX, NX 7510
Syntax
      process-cpu [falling-threshold|rising-threshold] <1-100>
    Parameters
              | process-cpu | Configures the EX3500‘s CPU utilization rising and
                falling threshold values. The system generates a notification when either of these
                limits is exceeded. |
              | falling-threshold <1-100> | Configures the falling threshold for the EX3500‘s CPU
                utilization
                  <1-100> – Specify the
                    falling threshold as a percentage from 1 - 100. The default is 70%. |
              | rising-threshold <1-100> | Configures the rising threshold for the EX3500‘s CPU
                utilization
                    rising threshold as a percentage from 1 - 100. The default is 90%. |
      nx9500-6C8809(config-ex3500-management-policy-test)#process-cpu falling-threshold 60
      nx9500-6C8809(config-ex3500-management-policy-test)#process-cpu rising-threshold 80
      nx9500-6C8809(config-ex3500-management-policy-test)#show context
ex3500-management-policy test
 http secure-server
 enable password level 3 7 12345678901020304050607080929291
 snmp-server notify-filter 1 remote 127.0.0.1
 memory falling-threshold 50
 memory rising-threshold 95
